Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: I think I blew my motor
  1. #41
    Jan 2005
    Louisville, KY
    Default That blows
    It goes into 2nd gear so easily at 100mph. I couldn't believe it either. I guess it turned out for the best b/c now I have a 4.0 in my car from a 740il. I wanted to do that swap from day one. I guess it gave me the necessary motivation. Check your trans mount bushings. Mine were completely torn up and I assume the main reason 2nd was right were 4th was supposed to be because the tranny moved to the side so much under heavy load. I got UUC's urethane mounts. Good luck!!! Oh buy the way when I disassymbled the engine I had valve marks on the pistons but the bottom end looked great.
  2. #42
    did you use the 740 trans?
    Jan 2005
    Louisville, KY
    I used the stock 530i 5-speed. I works just fine with the extra power from the 4.0.
  4. #44
    Orlando, FL (Gainesville)
    wow, deja vu all over again...i was in my buddys 92 nonvanos m50 when he went from the top of third into second and snapped the timing chain, bent all 12 exhaust valves...but his motor died instantly so I think your lucky it still runs!
  1. the headgasket blew :(
    Last Post: 07-24-2009, 08:51 AM
  2. F*n radiator just blew...
    By Boone.Msi in forum 5 Series BMW
    Last Post: 03-17-2007, 02:02 PM
  3. 2nd Gear blew up... Help
    By acidfire52 in forum 5 Series BMW
    Last Post: 02-20-2007, 11:15 AM
  4. Tire Blew
    By Macv in forum 5 Series BMW
    Last Post: 09-20-2006, 11:51 PM
  5. transmission blew
    By nariusb in forum 5 Series BMW
    Last Post: 05-20-2006, 07:05 AM
