Results 1 to 5 of 5
Thread: OT : The 523i was a dud ! ? Nikasil
    Aug 2004
    Regional NSW, Australia
    Default OT : The 523i was a dud ! ? Nikasil
    Half compression on 1 cylinder, corrosion in floor pan seams, leaks from every possible place......... the mechanic didn't bother to do the leakdown test given what a mess it was.
    I am still having trouble understanding if what my mechanic is describing is wrong with Nikasil engines in Oz is the Nikasil problem or something else.
    "Honing marks in the cylinder wall are meant to retain oil which lubricates the piston.
    In Nikasil lined blocks the honing marks are removed by the piston rings and the cylinder walls become too smooth and cannot retain the oil required for lubrication so the piston is running virtually dry.
    This then leads to excessive wear of the rings and loss of compression which replacement of rings will not fix for very long as the new rings also wear out very quickly. "
    Does this sound like a sulphur issue or something else.
    Any learned opinions ?
    By the way - discovered that they stopped putting Nikasil cylinder liners into our sixes in March 1998 (Thanks Shogun) so will look for a steel lined engine next time.
    "I'm not the village idiot.
    Aug 2004
    Bill R, Shogun, Whit...... Anyone ?
    Long Beach, CA
    Quote Originally Posted by Zeuk in Oz
    I'm having a hard time determining what you're asking. What is your mechanic recommending?
    I think what your mechanic is refering to is a worn cylinder or something.
    Nikasil is wear that occurs at the tops of the cylinders due to the nikasil plating coming off, nothing to do with honing marks and the such.
    Aug 2004
    Thanks, that is what I thought too, just wanted someone else to say it.
  1. E39 523i Estate Boot glass problem
    By beast in forum 5 Series BMW
    Last Post: 01-08-2007, 01:07 PM
  2. E34 525i Vs E39 523i
    By splower in forum 5 Series BMW
    Last Post: 04-05-2006, 03:58 PM
  3. Nikasil???
    By Incantation in forum 5 Series BMW
    Last Post: 03-23-2005, 10:30 PM
  4. Nikasil
    By spitfire in forum 5 Series BMW
    Last Post: 06-20-2004, 10:55 AM
  5. 320d or 523i
    By ronnysimonsen in forum 5 Series BMW
    Last Post: 02-13-2004, 04:47 AM
