Results 1 to 10 of 14
Thread: E34 engine loses power @ 4500 RPM
    Aug 2005
    Default E34 engine loses power @ 4500 RPM
    Engine runs strong til 4500 RPM, then power fades abruptly.
    Running thru the gears (5 Speed Man. Trans), engine runs superbly, then at 4500 it hits a wall. What has been replaced in the last year; new fuel pump, fuel pres regulator, oxygen sensor, & catalytic convertors. Rebuilt engine has 20,000 miles on it, in a 92 525i with 95,000 miles.
    Has anyone experienced a similar problem or have an idea what might be causing it?
    Thanks in advance!
    Fuel filter, rotor+disty cap come to my mind.
    Jul 2005
    Exeter, Devon, UK
    check the injectors as well... mine had a slight blockage in one... also check HT leads, distributor and rotor arm...
    Could just be something simple like the air filter.
    Feb 2005
    Richmond, TX
    No rotor and cap on an M50
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2000 323iT - UUC BBK, PSS9 Coilovers
    2005 GMC HD Crew
    Default If its not the cat plugged up again then i would check one or more of the
    coils for poor output, someone else had that same problem with an m50 and it turned out to be a couple of bad coils....
    Quote Originally Posted by e34fun
    Thanks in advance!
    That's what I was thinking....restricted flow at the cat. best, whit
    Feb 2005
    Richmond, TX
    He replaced the cats. Coils should cause a miss at idle if they are going bad.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2005 GMC HD Crew
    Default Baloney, even though he replaced the cats if there's a
    problem such as unburnt fuel it will kill the new cats very quickly. And typically a weak or bad coil will have more than enough energy to light the mixture at idle when with the throttle bore is closed. But not so when accelerating under load.
    Quote Originally Posted by brodee
    yep the old blow the spark out in high wind theory.
    I would check them (coils) first because even if you replace the cats your gonna dump more raw fuel in there and kazam! just like magic youll be asking the same question a month from now.
    OT: I used to be on a forum where guys would have super powerful ignition systems getting high speed miss...chasing things and spending thousands of dollars and of course I wouldnt get the credit for being nut on in the first place. You have high compression and a miss at 7000rpms...lets see here, whats the plugs gapped at .045...LOL Try .030...that would start all kinds of stuff going. I dont need to gap them that small I have 30 bazillion volts...whatever man.
  1. 95 525i shutters and loses power at 2500 rpms to 3000 rpms
    By caqueenslace in forum 5 Series BMW
    Last Post: 04-16-2009, 07:41 AM
  2. tranny revs up to 4500 rpm before shifting
    By anders in forum 5 Series BMW
    Last Post: 08-29-2006, 05:41 AM
  3. Replies: 27
    Last Post: 12-13-2005, 09:54 PM
  4. 535i loses power
    By gushmagesh in forum 5 Series BMW
    Last Post: 10-08-2004, 11:13 PM
  5. Replies: 4
    Last Post: 09-01-2004, 01:08 PM
