Results 1 to 10 of 17
Thread: Remanufactured MAF
    Keizer, OR
    Default Remanufactured MAF
    Just a tip: If you have a V8 E34 (probably E31, E32 and E38 as well), don't buy a reman'd MAF from AutoZone (CarDone).
    They listed this MAF as fitting my car, but it quite obviously does not It's almost 2" smaller in diameter than my MAF.
    Not even close to the same size. So now I have to find a place that will have a MAF for my car. Any suggestions outside of the dealer?
    Owner - Willamette Valley Motor Sports, LLC
    Jun 2005
    Cleveland, OH
    Quote Originally Posted by Shaun
    Patrick at BMA?
    I miss my e34
    Jan 2005
    Roseville, CA
    Quote Originally Posted by dacoyote
    Patrick at BMA?
    x2
    E34 540iA sold 1/06
    yep...get the right part the first time.
    I have 4 used ones here. All 4 are from 1988 E32 750iL and look like this.(pic from autohausaz.com, not original pics from actual parts)
    2 I bought for my stock last year from a German used parts dealer, these are from a car built 07/1988, the other 2 are from a parts 750iL from built year 10/1988 I bought here in Japan some months ago. This car has around 190.000 km (not miles) on the clock.
    I have never tested them, just keep them on stock.
    I am also not sure if they are identical to a V8 M60 or M62 engine MAF. Check that out on the realoem parts catalog with the cross reference key there.
    If you are interested, make me an offer.
    Keizer, OR
    [IMG]ttps://www.autohausaz.com/secure/PartImages/0986280111.jpg[/IMG]
    Thanks for the offer, unfortunately that won't fit either.
    Default yes, does not fit unfortunately, I just found out
    It's a pity, as the new ones or remanufactred ones are really expensive
    http://www.autohausaz.com/catalog/lo...Token=89902330
    What wears out in a MAF? the wire can break, I know that... surely it doesn't 'go off' (perhasp it can get dirty, but with a lot of TLC it sould be cleaned with isopropyl alcohol or some kind of CFC... TetroHydroChloride I think its called... ? GP
    Oh, its I forgot, its a BMW:
    I meant to say, what wears out - apart from the connector?
    When the air-mass sensor is working normal, the hot wire does not glow. To burn off any deposits and dirt, the control system will heat the wire red hot to 1000 degrees Celsius (1800 F) for about 1 second, after you shut off your engine. This is the cleaning process and only performed if the engine is revved up to at least 2000 rpm. So starting your engine, let it idle for a certain time and shut off means no hot wire cleaning.
    http://shrubbery.student.utwente.nl/...leshooting.htm
  1. Remanufactured Clusters... Source?
    Last Post: 06-13-2010, 04:57 PM
  2. 4HP22 Remanufactured Starting bid: $ 700
    Last Post: 11-12-2007, 12:25 PM
  3. Python remanufactured AFM
    By SRR2 in forum 5 Series BMW
    Last Post: 03-21-2006, 08:49 PM
