The clutch has a separate "master cylinder" from the brake system. I can't tell from your post if you're having clutch or brake problems. If you're having clutch problems, I'd carefully inspect the slave, the line and then if they look ok, the master under the dash. Try carefully bleeding them if you're still having issues.
