Radiator tank leaking
Ok, this is really odd.
I've got a 1991 525i Touring with a relatively new radiator...
I go to take off the filling tank on the radiator because it was full of sludge at the bottom and I wanted to clean it. I NEVER had any problems with the tank previous to this and I was very careful at taking it apart.
After re-assemble, the edge of the bottom of the tank right where it seals into the radiator seems to be leaking. Its not leaking a WHOLE LOT, but it will leak out the contents of the tank within a hour or two. I pulled it out, checked the seals, checked the o rings, they all looked perfectly fine.
BUT: There are 2 grooves for o rings on the seal from the tank to the radiator. The BOTTOM o ring is there, the top groove never had an o ring present.
Maybe its bad o rings? Anybody ever hear of this issue?
I'm technical saavy, already replaced the entire cooling system due to the previous owner loosing a metal piece in the radiator that ended up ruining everything in the dam system!
This little issue is givin' me greif!
- 2001 E46 330i Sedan
- 2000 E36 Dinan M Roadster (S52 / 270hp)
- 1991 E34 Touring Sport (project car)
I'm still learning, so bare with me!
