Radio reception interference is usually the result of electrical noise - in your case, it sounds like you have a brake switch that's dying on you. In my case, I got a "Brake Light Circuit" warning on the dash read-out and intermittent brake lights. The switch is a pain to get to, but easy to replace. If that's not it, then maybe there is a loose connection or frayed wire in your brake light circuit. Hope this helps.
