what do u mean without the right pins?
some will be empty, they are for other configurations like diesel and other engines and air con and stuff like that
there is no right configuration, only wrong ones!
Does anyone know the right arrangement for the relays in the fuse compartment box?. 2 ports are empty in mine and there are some without the right pins. (1990 525i)
I will appreciate your inputs guys!
regards
Phil
thats great but only survives to complicate his question, i say this because that view looks nothing like mine! so its only going to cause more questions.
Thanks for your effort BUT I guess this is for 7series as it is different from mine. I appreciate it though.
I dont think you are getting this Demi, not only does it depend on what options are fitted it varies depending on age
perhaps if u told us why you wanted to know, like something wasnt working correctly
if everythings fine i dont quite follow why you need to find out what fits in the blank space as it will serve no purpose
Javier
UKM5,
I want to be sure that the right relays have been used cos I discovered the relays I saw did not have exactly the same no of the socket pins. So, I wanted to know what would be the effect of this.
Thanks Javier. You have fully answered my question and concerns. I appreciate ur help.
Regards.
