Results 1 to 7 of 7
Thread: Brake Upgrade Opinions
    Apr 2005
    Default Brake Upgrade Opinions
    I am planning on upgrade the brakes on my 89 535, I have read up and found that I could go with E31 (8 series) fronts and E34 540 rears. It seems pretty easy to find the 540 rears but the e31 fronts are hard to get and from what I gather, rather expensive. The other option for the front would be the e32 740/750. I know how much force the 8 series fronts produce but dont know what the e32 brakes make. I can get everything for $700 (calipers, rotors, pads) for the e32/e34 setup. Should I wait around and find the 8 series fronts or if I am just using the car as a daily driver should I not spend the extra money?
    http://www.bmwe34.net/e34main/upgrade/brakes.htm
    Read up on how you can upset the braking balance before juming into something that could be dangerous on the highway.
    I have the plain old stock brakes and havent had any problems whatsoever...I wont do the upgrade.
    Feb 2005
    tyndall air force base
    i wouldnt go that hardcore if its a daily driver. I have the same vehicle and im just buying a setup from bmp...but its all up to you, 8 series stuff would be pretty expensive if u ask me
    F/A-22 maintainance specialists USAF
    Tyndall AFB FL
    Nov 2004
    Split, Croatia
    If I upgrade both the front and rear brakes to Euro M5 ones, would I upset brake balance?
    After switching to 17" wheels I planned to add brake ducts and switch to larger brakes, and the Euro M5 was the most logical choice.
    is it on Brunos brake comparison page?
    Nov 2004
    Split, Croatia
    "The '95 Euro M5 brakes generate 646 LB-ft front and 336 LB-ft rear, giving a bias of 66:34. Everyone raves about this setup, which is interesting as the front brakes actually generate LESS torque than the earlier E34 M5 (or the 540i, for that matter)! Chances are that this perception of awesome brakes has more to do with the better balance front-to-rear than the massive cooling capability, which only comes into play when you're driving the piss out of the car and the brakes are generating many kilowatts of heat. Unless you go to the track, you'll never encounter that aspect of their performance."
    Apr 2005
    so what is the consensis for pads if I am just upgrading the pads?
  1. Is this brake upgrade possible for an e34??
    By sneekens in forum 5 Series BMW
    Last Post: 05-01-2007, 09:31 AM
  2. Speaker upgrade..Opinions
    By HIe34 in forum 5 Series BMW
    Last Post: 04-05-2007, 06:21 AM
  3. e36 brake upgrade
    By ///MPOWER in forum 3 Series BMW
    Last Post: 01-23-2006, 05:29 PM
  4. What's a sensible brake upgrade?
    By Jay 535i in forum 5 Series BMW
    Last Post: 08-15-2005, 08:00 PM
  5. Brake upgrade questions
    By spddmn713 in forum 5 Series BMW
    Last Post: 01-15-2005, 10:36 PM
