Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Can't open front passenger door
    Wellington,New Zealand
    How do you do that?
    what jeff said
    Gone but not forgotten
    I will try force. Thanks to everyone for the hepful ideas.
    Mar 2007
    Liverpool UK
    I had a similar problem with the same door - i took the plastic door pin offand poured a bit of 3-in-1 oil down there, left it for a bit and voila - door opened! Helped me - anythings worth a go right?!
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Reading, UK
    I had a similar problem in my '91 525i try the following:
    From the drivers door:
    Turn key all the way to deadlock
    Turn key to unlock
    Turn key to lock, just to the point where the locking motors cut in, but are not deadlocked.
    Turn key to unlock.
    This would usually cause my passenger door lock to pop open...
    Feb 2007
    GreenHills East-Philippines
    hmm..sounds like your passenger door is stuck at deadlock
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    my driver door was double locked and stuck like that for a little bit, but what i was able to do
    open the window and start pulling on the pin slightly, then with your other hand use the key to try and unlock the door, while pulling up on the pin with more force and it should pop free
    worked first shot with me
  1. Rear Passenger Door Will Not Open.
    By Knockback in forum 5 Series BMW
    Last Post: 04-03-2014, 03:58 AM
  2. Passenger side front door rust free needed in GA
    By VentoGT in forum 5 Series BMW
    Last Post: 06-19-2007, 03:05 PM
  3. Passenger Door wont open...
    By Boone.Msi in forum 5 Series BMW
    Last Post: 01-12-2007, 08:19 PM
  4. e34's front passenger won't open from outside
    By sneekens in forum 5 Series BMW
    Last Post: 05-20-2006, 10:10 PM
