Originally Posted by
juan525i
92 525i, have had the car for almost 2 years, sin ce i bought it the message was always on but theres was no "limp mode" just an aanoying message. 3 months ago it started going into limp mode only after driving it about 20 to 30 minutes in the mourning. went to brunos site did everything he said.
1. checked battery, alternator (good)
2. checked cleaned DME, fuel pump relays. did not replace them!!!
3. checked and cleaned all switches and connections in the shift area.
4 replace fluid in tranny
5. replaced the tranny speed sensor($70)
--then from a post here i heard that the "band apply solenoid" always goes bad and that may be the culprit, had my hopes up and changed it $45 put evrything back together and stiil going into limp mode only after 20-30 minutes of driving and when i stop at a red light it happens.then--
--took it to bmw specialist did a computer check on engine and transmission
and it showed....
1. "o2 sensor control" on engine check..
2. "magnetic converter clutch" on tranny check..( TCC solenoid)
--I ordered the TCC solenoid $75 hoping that this problem was going to be finaly over, i installed the new solenoid yesterday and took it out on a test drive feeling relieved, drove to my girlfriends house and on my way back 20 minutes later it happened again, "limp mode". i am so frustrated and i really need some good advice because i have tried everything and nothing has changed, please advise me on anothere possible culprit. remember that the "trans program" message has always been there since i bought the car 2 years ago but it never went into "limp mode" until 3 months ago.
--somebody said that grouding one of the pins i dont know where erases the problem, correct me if iam wrong but i need any help or advice i can get..
The grounding of the pin only "works" to mask a false reporting of the failure from the tranny control unit to the check control module.... If you are going into limp mode.... it won't help you.
Scott
07 525i 22K, 07 328xi (41K)
