depends how warped it is, i've had several heads cut for customers and had no come backs for that, some shops can straighten a warped head in a special oven with clamps, i've never tried this service
okey, long story short here....
car overheated, blew headgasket (last time i let my dad drive the car ANYWHERE!!!!)
From what i've heard odds are that it warped the head. My question is.... is it worth it for me to get a new head or just to remachine the old one? I've talked with two people so far, i said you can remachine it and it'll be fine, the other said remaching will work, but its likely to crack down the road.
Anyone care to chime in on this?
interesting...i heard the M5 head was a little different because of the higher temps...any truth?
more than 12 mils of material. At least this is the case for the M30 according to Bently.
hector
hrm...anyone have a bentley for an M5 around? mine is at my parents house :-\
Originally Posted by TheGeak
yeah, i figured the manual would say something like that. BMW makes no money if you resurface a head as opposed to buying one from them. I was more curious as to if anyone had done it.
may as well take a looksee in the catalogue and see if there's a hidden specification for resurfacing...
its a '91 3.6L
the catalogue would have part numbers for the m50 extra thick gasket, therefore listing one for the m5 if one existed, but no, the thicker m50 isn't listed, both are set at 1.74 mm, and the TIS says m5 head cannot be resurfaced....maybe if it is cracked you could get someone to weld the crack, or thicken iit if it needs to be milled, as i doubt you're going to come across a m5 head easily.
