Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Overheating Woes
    Aug 2005
    Jamaica
    Default Overheating Woes
    My 1989 520i Bmw is overheating still. The thermostat, radiator, fans, water pump and fan clutch are all working fine. When I start the car, the temperatuture needle moves past the 12:00 mark and heads for the red.I first noticed the overheating when I was driving in traffic. I stopped the car as soon as I noticed that the guage was close to the red zone. Help!!!!!!!
    Default Since this is a 520i its obviously not a US market car and the european market had a
    m50 motor available in 89 in the 520, I would venture to guess that you have a plastic impeller water pump on your 89 520 and that the impeller is broken or slipping, it will look fine from the outside and will spin fine from the outside but the pump won't move much water and the car will overheat. Remove your water pump and inspect it.
    Quote Originally Posted by julielewis
    Aug 2005
    Jamaica
    Bill, the water pump has a metal impeller and it seems fine. What do you suggest?
    Default If everything is fine as you say then theres not many other possibilities,
    cracked head or head gasket seems most likely.
    Has it been properly bled? Are the hoses rock hard when it's running? (indication of bad head gasket/crackhead)
    Default Jeff, It has a 2 bar pressure cap on it.. thats about a
    29.4 pound pressure relief on the cap, so if it warms up the hoses are going to be rock hard whether its got a blown head gasket or not at 29 psi, especially when your used to a 13 or 14 pound system on an american or japanese car.
    Aug 2005
    Jamaica
    It has been bled over and over. The top radiator hose is hot and the bottom radiator hose is cold.
    Sounds like you're having flow problems... When you say the radiator is fine, what do you mean? Have you had it flow tested to make sure it's not blocked?
    Is your coolant expansion tank attached to the radiator, or seperate next to the firewall? If it's near the firewall, the line between radiator and tank can clog causing overheating.
    Long Beach, CA
    Quote Originally Posted by Dan in NZ
    If it's the original radiator, it might be time to replace it. I was having cooling problems and decided to overhaul the cooling system. New radiator, water pump, thermostat, hoses and belts. It was under $400 in parts and we did it ourselves. No more cooling problems.
    Aug 2004
    Dubai
    heating up that fast might be a cloged radiator, but this engine cracks the head faster than you would expect, especially if you tried to cool it down by adding water while still hot. check the coolent for any chocolate colore fluid also notice the hoses if they are expanding like a snake then for sure the head is blown or the head gasket.
  1. WTF? radio woes
    Last Post: 09-18-2007, 02:30 PM
  2. CCM Woes
    Last Post: 11-09-2006, 05:49 AM
  3. Web Woes?
    By Paul in NZ in forum 5 Series BMW
    Last Post: 02-15-2006, 09:13 PM
  4. Air Conditioning Woes
    By DCR in forum 5 Series BMW
    Last Post: 11-26-2005, 03:16 PM
  5. New guy has aux fan woes
    By Jay 535i in forum 5 Series BMW
    Last Post: 08-10-2005, 10:44 PM
