1, no
2, ditto pull harder, you could loosen the bumper shocks and that may be enough
3, on a m50 motor it's dead center under the intake and sorta T shaped with a 3 wire plug
4, if those two hoses coming from the valve cover are not connected they could be making a vacuum leak screwing up the idle and misting oil out, the big one goes to the intake boot where it goes into the throttle body (sometimes it goes to a short metal tube on one of the intake manifold supports and then to the intake boot) and the small one goes to a nipple on the fitting that the idle control valve (that one would be a vacuum leak if not connected)
![Quote](images/misc/quote_icon.png)
Originally Posted by
liquidtiger720
1. Should I be worried about the mixed coolant? (green + blue )
2. How should I get my bumper off? -Its stuck-Look at picture of bolts
3. And lastly...Where the heck is the Idle Control Valve? I can't even find it in my Bently. I need to clean it or something, cause I've got a rough idle =,(. (most important)
4. I have a oil leak at the top, Can't tell what it is. Coming from the two hoses coming out near the front of the engine (right next to the vanos).
