Results 1 to 7 of 7
Thread: I went crazy with the 535i....
    Default I went crazy with the 535i....
    ...and I hope not to regret it. Blew the tax return on the following:
    From BMA: 1340.00
    M-Tech sways
    Sachs kit.
    control arms
    thrust arms
    4 sway links
    motor mounts
    rear shock mounts
    various minor parts.
    From Mark D. 164.00 Winter sale! Thanks Mark.
    EAT chip
    From Ebay 450.00 with shipping
    8-series wheels
    From Tire Rack - 360.00
    Kumho 225/55/16 HR tires (5)
    Took to mechanic who had done my rear subframe bushings last year for 600 bucks.
    He added that I needed:
    dogbones
    trans mounts - these were TRASHED!
    4 new rotors - his recommendation - zimmerman cross drilled
    oil change
    mount and balance tires
    oil change and plugs
    alignment
    He is charging me.....gulp....about 2 grand.....for his parts and labor.
    I hope it is all worth it. 140k miles on the car and it needed the entire R&R...
    I will let you know how it all turns out as I pick it up tomorrow.
    I am one broke puppy and I need a minor lotto win.
    1991 535i + EAT + Sachs + MTech Sways =
    around Toronto, Ontario
    That guy is taking you to the cleaners. A clutch job isn't worth 600 (with parts), let alone the subframe bushings. I paid 200 Canadian to get mine done.
    Quote Originally Posted by bighc2000
    From BMA: 1340.00
    M-Tech sways
    Sachs kit.
    control arms
    thrust arms
    4 sway links
    motor mounts
    rear shock mounts
    EAT chip
    8-series wheels
    dogbones
    oil change
    alignment
    You gotta pay if you wanna play...
    I would do all myself and skip the crossdrilled rotors,
    just my 2¢
    Good Luck!!
    Chicago
    I don't know your situation with available time and wrenching experience, but if you gotta do what you gotta do, then so be it. Even if it means spending 2k on shop work. You will definitely love the new upgrades. Keep us posted...You will definitely be smiling for hours.
    I too would skip on the Zimmerman crossdrilled.
    Brandon J
    I heard the crossdrilled warp easier than the stockers, is that brand specific or apply to all the cross drilled rotors?
    I am not a wrencher and am quite busy with work. I am also working on building a house. When I move in, I will try to start working on the car myself. I am not afraid of engine or other minor work but the suspension stuff = forget it.
    I do trust my mechanic a lot. He takes the time to invite back into his service bay and will show me exactly what the problems are and his suggestions to solve them. he is slighty pricey i guess but he is convienient and next door to the stealer(Erhard in Farm Hills)
    He laid out the pros and cons for all of the rotor options and I picked the Z rotors. I'll have to live with it but can't to try out that EAT chip.
    I cannot believe how bad my trans mount was. I will post a pic if he has not thrown out the part.
    As long as you are comfortable with your choices then you are fine. Most of us here do work on out own cars and do as much as we can to help each other out. If I was not so financially challanged at the time there are a lot of things that I would rather just have serviced than do myself but it sounds like you have an excellent mechanic to help you out. You will be able to enjoy your 535 a lot quicker than most here and be sure you post the results after you have everything taken care of. Once you do have time to tinker with it we will surely be happy to help you out with any questions you might have.
    Good luck and enjoy!!!!
  1. OT crazy
    Last Post: 11-09-2006, 10:05 PM
  2. crazy (pics) meh 56k
    By kyleN20 in forum 5 Series BMW
    Last Post: 06-21-2006, 07:43 PM
  3. OT, thanks but no thanks.... crazy people
    Last Post: 10-30-2005, 08:50 AM
  4. rusting like crazy
    By McWatters in forum Body & Interior
    Last Post: 08-28-2005, 08:52 AM
