first of all welcome to the group
1. The head gasket appears to need replacing.
---It's not really bad
2. When firing up, the engine runs rough and revs rough.
---have you checked the valve cover gasket / Plugs
3. There is some trim broken on the driver's side door.
---Easy Fix
4. One of the headlights is broken (lamp ok) and one is out (probably just lamp).
---Bummer
5. The interior of the car is about a 4/10 or so, with the seats showing wear and some of the trim (around the shifter) is well worn. The four-way flasher switch is broken and others well worn.
---You can try to clean up the leather and so, the flash switch is a easy one to fix
6. The instrument cluster is not fully functional. The gas/temp guages are not working as well as the electronic area on the lower part of the cluster (showing the # of k's on the car/trip I would think).
---bulbs / capactors
7. No stereo (might be an issue due to the speaker systems in these cars)
---There are a lot of people that can help with that
8. The driver side rear door handle appears to be sticky (may just be a lube issue).
---I would try lube first
9. Windshield needs replacing as well as wipers.
---Bummer and normal wear and tear
10. Front tires need replacing.
---Normal War and Tear, did they wear even?
The entire group here is cool, everyone loves their car.
I would suggest getting a Bentley book and starting on the engine stuff first. Do you have any sort of service records for things like the tranny and the like.
-Charles
