umm... from BMW?~ $5000
brand new 520 i engine needed, where can I get it from
the e34 went out of production over 9 years ago almost, and you want a brand new 520 engine to put in your low spec 520
think you need to readjust your medication mate
BMW 520i 79 - 84 4 Zyl 8V M 10 2,0l komplett 400 Euro
BMW 520i 87 - 90 6 Zyl 12V M 20 2,0l Grundaggregat 1500 Euro
BMW 520i 89 - 95 6 Zyl 24V M 50 2,0l Grundaggregat /ohne Vanos 2100 Euro
BMW 520i 89 - 95 6 Zyl 24V M 50 2,0l Grundaggregat /mit Vanos 2100 Euro
These are remanufactured engines by a German engine rebuilder.
Grundaggregat = basic engine
ohne Vanos = without Vanos
mit Vanos= with vanos
Die angegebenen Preise sind unverbindliche Richtpreise und verstehen sich bei Rückgabe eines typengleichen Altmotors im gleichen Lieferumfang zuzüglich Mehrwehrtsteuer.Bei Nichtrückgabe oder nichtidentischen Altmotor erfolgt Nachbelastung bzw. verfällt der Pfandeinsatz. Pfand 500 Euro.
Grundsetzlich ist bei allen hier aufgelisteten gebrauchtüberholten Motoren folgendes erneuert worden.
Alles was dem Verschleiß unterliegt.
Pleullager,Venitle,Dichtungen,Kolbenringe
Teilweise sind neue Kolben,Zylinderköpfe,Kurbelwelle,Pleulstangen verbaut worden,genaueres bei Ihrer Anfrage.
translation:
the prices indicated are non binding budget prices and are to be understodd based on return of the old defective engine of the same engine type with the same scope of supply, plus value added tax. In case of no return of an old engine or non-identical engine the prepaid 500 EURO (core price for the old one)will not be refunded.
Basically all lised engines are remanufactured and all wear parts were exchanges such as bearings, vealves, gaskets piston rings, partly are also new pistons, cylinder heads, etc. installed. details upon request.
Note that this is the BASIC engine only!
More details here
http://www.zylinderkopfcenter.de/Welc.htm
I take it there's no chance of getting hold of a good used 520/525 M20 engine? Anyway, what's wrong with yours?Originally Posted by aabdelhamid
Cheers,
Shaun
