Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Fixed my twisted seat (and learned some things)
    Nov 2004
    Winston-Salem, NC
    Default Fixed my twisted seat (and learned some things)
    Hey All,
    I just finished fixing my serously twisted driver's seat!! Now the seat back is straight and timed so that both sides moved together! Although, the fixing of one problem highlighted another. Nowmy seat sits higher than the pass-side andmy head touches the ceiling, argh!
    So after 1 trip to a friends house, 1 trip to Lowe's, a dirty sheet (floor covering), and sore fingers I learned some things.
    1) I need a remedial Bentley manual - I spent 20 mins looking for the seatbelt height thing on the FRONT rail of the seat
    2) No job is ever a 15 min job (I started at 7:15 it's now 10:30--time does include borrowing tools and the trip to Lowe's
    3) When the directions call for a torch, use a torch!
    4) Always read the directions first!
    Whoo-Hoo can't wait for the valve cover gasket I'm doing on friday!!!!!
    Thanks for the help!
    -ashley
    BTW http://bellsouthpwp.net/m/i/miales/seatcablesfix.htm is where to check first, GREAT PICS!
    Paper Gaskets Suck!
    ukm5 Guest
    thankyou for sharing those invaluable snippits of wisdom with us, im sure they will benefit us no end.
    I just did the cable fix on my new (to me) memory driver's seat. The head rest wasn't working. Took a bit longer since I don't have any 1/4" sockets or an 8mm gearwrench at home, but what can you do.
    Now Fritz has a memory seat -- next up is sticking on the mirrors, steering column, and can't forget the pass seat
    Good luck with the valve cover gasket!
    best, whit
    Long Beach, CA
    Doesn't your seat adjust up and down like mine? The other switch than the one you used for the tilt moves the seat back and forth and adjusts the thigh support higher and lower. It's the horizontal seat adjustment lever.
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by uscharalph
    Ralph,
    Yeah, it sounds the same it's just not working right. One side of the seat moves up while the other stays put (at one point it also makes a really neat clicking/grinding sound). I actually think I have the same problem with the second set of cables under the seat. I couldn't figure out how to remove the motor to access those cables. It's mounted underneath the lip of the seat and by 10:30 I was pretty tired of dealing with the seat.
    I will most likely pull it back out tomorrow after I do my valve gasket and try to shorten the cable housings there too.
    My PO had this car serviced at the same dealer from the time he bought to the time I bought it and I am NOT impressed with their level of competence. The cables I repared last night were replaced four years ago to the tune $138 each plus labor and they didn't even put all the bits back correctly!
    Anyway, I give ya update soon.
    -ashley
    Paper Gaskets Suck!
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by ukm5
    ooo...sounds like somebody woke up on the wrong side of the bed!
    Paper Gaskets Suck!
    Jul 2005
    Agoura Hills, CA
    Mine took 2 hours. Twice and its still not straight. I keep over compensating on one side - then the other.
    A lighter was sufficient to heat the end to remove it for me.
    My problem is that I am 6'3" with bad knees.
    When I did my seats, I went ahead and did all the cables since I had my torch all set up. Well, since I had my box of matches out... 6 cables per seat IIRC.
    Robin
    72 Chevy K10
    01 E39 M5
    Jun 2005
    Cleveland, OH
    Good Job... and good luck on the cover gasket, I did mine about 2 months ago....
    Not the hijack the thead... but the button that is futher back of the two... the one that leans the seat back and forth.. what is it suppost to do when you press up or down on it... I cannot feel anything change in either seat....
    -Charles
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by dacoyote
    -Charles
    Charles,
    If it's the button I think you're talking about it should be the headrest adjustment. That motor and cable is located in the backrest of the seat.
    -ashley
    Paper Gaskets Suck!
  1. Twisted seat fix for E34
    By Al Gray in forum 5 Series BMW
    Last Post: 10-28-2007, 07:04 PM
  2. Twisted seat fix
    Last Post: 07-14-2007, 10:43 PM
  3. Replies: 3
    Last Post: 02-09-2006, 05:41 PM
  4. Think this seat was a little bit twisted?
    Last Post: 01-31-2005, 01:51 PM
  5. 2 things I learned today:
    By mikemaster in forum 5 Series BMW
    Last Post: 11-06-2004, 07:00 PM
