Results 1 to 3 of 3
Thread: simple wash water tank question
    Default simple wash water tank question
    When I bought my Highline it had no wash water tank, probably broken and removed by P/O.
    Now I got a used one. There is on the 750 a steel heat shield between tank and engine. This is popped into 3 plastic holders which onto the tank.
    Looks like these vacuum suction taps/caps but they are actually inserted in a kind of plastic ring on the tank.
    2 of these are slipped out from the tank 'ring'.
    How to insert them again? Just pushing it it or heating up in hot water? Am a bit afraid that the plastic will break. Paid on the net for that used thing abt. 80 $ plus postage, incl. 2 pumps.
    Sorry for the not so detailed explanation but I assume you know what I mean
    That is how it should be attached.
    The explosion view
    Wellington,New Zealand
    They look like those "washers" that have say three tabs on the id which grip the short plastic stud on the tank.I Dont know if there is a tool to put them on and take them off....ie they come with the tabs pointing up or down and you "flatten" them to make the tabs grip the plastic.....
    Gone but not forgotten
    Paul,
    I know how to remove the # 10 washers. I mean on the back side of the heat shield plate, there is something made of plastic which is either glued or 'plastic welded' onto the tank.
    So the problem is the attachment of the 'base' of the plastic which is attached to the washer tank where the screw is in a round shape piece of plastic. The drwaing for the part s catalog is not 100% correct.
    Looks similar to these plastic cups for attaching the solar panel to the front window. But it is solids plastic. Assume it broke off.
    http://i23.ebayimg.com/02/i/02/02/cc/ea_1_b.JPG
  1. Simple Question
    By begeta50 in forum 5 Series BMW
    Last Post: 04-10-2007, 11:40 PM
  2. Removing front seats - simple question
    Last Post: 03-17-2006, 11:25 AM
  3. Overflow Tank Question
    By av8r in forum 5 Series BMW
    Last Post: 02-03-2006, 07:23 PM
  4. Replies: 7
    Last Post: 09-05-2005, 05:30 PM
  5. A simple question (i hope)
    By Wyn in forum 5 Series BMW
    Last Post: 05-12-2005, 11:07 AM
