of course it will still make power fine. it will be dead within 2 months because of the cooling fan running in the wrong (backward direction), but it will make power well up to that point....IIRC, it might make SLIGHTLY less power if you run it backward because of a slight lessening of tension on the brushes when the commutating surfaces are running the other way.Originally Posted by Jon K
id probably take the alternator to an auto electrician and have them inspect the mechanism and see what the story is WRT your fan(s). im looking here for a picture
http://www.rangerovers.net/repairdet...haltrepair.htm
if you have a two fan unit (i don't know what's in your particular car), you might be able to switch the fans from top to bottom and reverse airflow. or maybe the auto electrician can find you a blade that works in the reverse direction, i have no idea which. but i wouldn't run it backwards longer than needed for testing.
