Originally Posted by
SRR2
The caps don't act as batteries. The trip odo is stored in solid state memory and requires battery power to retain. Disconnect the battery and the memory is dumped. The caps in question are used in a switching power supply that powers various parts of the cluster. When they go bad the power gets very 'dirty' and the circuitry that uses it may or may not work correctly.
Just a couple of months ago I replaced every electrolytic cap in the cluster in my '89. Not only did all the cluster gremlins go away, but .... seriously, I'm not making this up and my wife can verify it ... the radio reception got a WHOLE lot better. The only explanation I have for this is that the cluster must have been emitting a lot of hash due to the bad caps and noise on the long traces (think antenna) on the board, and that was interfering with AM reception.
When you have the cluster out you should replace the high-usage lamps, like the odo, check-control, and auto-trans annunciator if you have one of those. In my cluster the odo lamp was so degraded with tungsten deposits on the glass that it was barely readable. The difference with a new lamp was amazing. BTW, not all those lamps are created equal. I bought a bunch of them and screened them by cold resistance. I put the lowest-resistance one in the odo. It's nice and bright now.
