Hi folks,
I just bought a 1990 535i, 128k miles, auto trans. I have several questions that perhaps some of you could help me with.
I didn't buy this car for relaibility - mostly I bought it because I want (need!) RWD and refuse to buy the trash detroit sells. I plan on it being tempermental, and that's OK. I've been looking for a 535 for a while, and I really like the layout of the straight big six motor. I plan to perform all regular maintenance, and have done all the work on my japanese cars. But this is my first german car.
Items I've seen come up over the past two days are:
There is a groaning sound coming from the rear of the car when turning at low speeds. It only occurs when turning, never going straight. I'd assume wheel bearings, except it happens equally when turning either direction. It almost feels like something is grabbing / tugging back there. Is there something else in the suspension? A trailing arm bushing perhaps - that would cause the tires to fight against each other? The tires are spankin' bran new, so I can't tell if there will be any wear patterns yet.
It seems to be leaking coolant from the upper radiator hose where it meets the radiator. It has a screw type clamp on it. Is that correct, or should it have a spring clamp? It's rather tight, and I don't want to break the radiator by clamping down on it too hard. The hose seems fine, as does the radiator. It just leaks. My fear is a leaking head gasket causing excessive pressure build up, but my local european auto mechanic disagrees (after an over the phone diagnosis). Ambient temperature yesterday was 98 degrees. The needle stays less than a hair's width above the 1/2 mark on the gauge. After shutting off while hot and restarting 20 minutes later, the needle sprung up to the 3/4 mark, but fell back down to 1/2 after driving for a few minutes. I imagine the sensor was just sitting in a hot spot and went back to 1/2 after the coolant started flowing. I don't know any repair history, and I know this car is prone to overheating. Shall I just replace the clamp? Flush the system for good measure? Or be paranoid and start replacing parts for fun?
And: I can't check the transmission fluid. It doesn't have a dipstick (or so it seems to me). Am I
!? There is just a cap on the tube where the dipstick would go, and I can't remove it. Was this a no-tamper device for the US market to drive more customers to the service dept?!
And: Should I pay $50 to have the oil changed by the dealer so they can reset that service interval thinger? Or should I do it myself? The manual doesn't specify oil change intervals, so I'm thinking it's doing some kind of algorythm to determine, by its self, when it wants new oil. Maybe an hours of operation combined with number of revolutions, or something? I like to honor that, if that's what it's doing. But if I can't reset the service indicator, then I'd have to just start doing it based on milage.
And: The owners manual says that 10-40 oil should be used between 20 degrees and 70 degrees. 10-50 oil lets it go up to 80 degrees. But here in Utah we're routinely around 100 degrees. That would call for 15-50! That seems absurdly thick! I know this motor was used by BMW for decades, and it's probably an older design - but should I really put 15-50 oil in it?!
Finally: If I put the transmission into manual shift mode, it does it every time. If I attempt to put it back to automatic, it does it about 1/2 the time. I have to keep driving and fiddling with it, and eventually it switches back. Is that a problem with the switch, or with the transmission?
Thanks for listing to all my questions! I want to take good care of this car that really appears to be in excellent shape for its age at this point.
Aaron
