I've never used it, but the cost is very reasonable. My head gasket failures left no doubt where problem was.
The mfr has some photos of device in use.
http://www.lislecorp.com/tool_detail.cfm?detail=1332
http://www.lislecorp.com/tool_detail.cfm?detail=1335
Paul Shovestul
Originally Posted by
shogun
Someone tried this one or has better recommendation for a DIYer?
Automotive Combustion Leak Detector by Lisle
SKU: LIS-75500
Quickly Pinpoints Automobile Combustion Leaks.
Checks for combustion leaks caused by bad head gaskets, cracked blocks, and cracked or warped heads. Fluid changes from blue to yellow when exposed to combustion gases from the radiator. Connect the hose to any vehicle vacuum line. Or, on tools made after June 2002, use the red adapter with a hand vacuum pump. Place tapered end of tool into radiator opening. With the engine running, the vehicle vacuum or the vacuum pump draws vapors through the indicating fluid for testing. Diesel adapter included.
http://www.tooldesk.com/products/pro...l.aspx+id+1800
