Results 1 to 3 of 3
Thread: A/C Help
    Nov 2004
    Winston-Salem, NC
    Default A/C Help
    Hey Fellas,
    My 525iA has a build date of 9/92 and a service manual that says 1993 on the front cover.
    My A/C commpressor is failing. It still blows very cold, but the mechanicals are going south. The 1993 e34's used R-134a as the refridgerant, while 92's used R-12.
    Here's my question:
    Which one do I have? Build says 92 service manual says 93. Are there any markings on the compressor that would identify it as either r-12 or r-134a?
    -ashley
    Paper Gaskets Suck!
    Long Beach, CA
    There should be a sticker at the front of the engine bay.
    R134a should have different High and Low pressure fill fittings than the R-12.
    The R134a ones won't have any threads on the outer surface of the fitting and the Low side one with be smaller than the High side one.
    DanH
    1989 535iA 254k Miles
    1992 535iM 330k Miles
