Results 1 to 4 of 4
Thread: hazard light switching on on it's own?
    Default hazard light switching on on it's own?
    I had a similar case 2 years ago. Hazard lights went on while driving. Took me quite some time to find the culrpit. Cleaned the hazard switch and other things. Nothing helped.
    Finally I replaced the crash control module in the fuse box and the problem was solved. It is the brown one right of the CCM.
    This crash control module has the following function in case of a crash:
    switching on courtesy lights, unlocks door locks, switching off fuel pump(s)
    http://www.nmia.com/~dgnrg/page_22a.htm
    pic is from gale's page.
    ukm5 Guest
    on the E34 its located under the rear seat just next to the tunnel, connected direct onto the bodywork
    Quote Originally Posted by ukm5
    Actually, Shogun's correct on this one, although it depends on the MY of the car as to exact location under the hood.
    best, whit
    The crash sensor sits under the rear seat. This brown module or relay sits in the fuese box. Actually I just have it here on my desk. Correct name in German printed on it:
    Crash-Alarm-Geber 12V-, Teilnr. 1 384 732 (on the other side is printed 84552N). The new p/n I got is 6135 8364 691.
    Man, I tell you, that worried me about 3 months and I couldn't find it.
    Here you can see the inside parts
    http://www.pagaduan.org/bmwe32/index.html
  1. How to remove the hazard switch?
    Last Post: 12-10-2009, 08:57 PM
  2. Hazard flashers come on by them selves
    By bimmo_2007 in forum 5 Series BMW
    Last Post: 11-14-2009, 10:52 AM
  3. Transistor switching and the SRS light
    Last Post: 07-27-2009, 05:22 PM
  4. How to remove Hazard Switch?
    By NitrousO in forum 5 Series BMW
    Last Post: 03-17-2006, 04:57 PM
  5. What can I use for a contact in the hazard switch?
    By RobPatt in forum 5 Series BMW
    Last Post: 07-01-2005, 11:27 PM
