Results 11 to 20 of 25
Thread: What do you guys haul in case of emergency?
    Aug 2004
    Milwaukee, WI; Chicago, IL
    Keep the ideas coming.
    I hope those of you who travel light never get caught off guard at the wrong time.
    1990 BMW 535i 5 speed - Black on Grey, LSD
    PA
    I don't have room for spare, jack, etc.
    So i have a cell phone, AAA card, wifi internet, etc etc etc
    California
    45 Magnum
    lie
    shovel
    T·O·R·O·N·T·O
    Does no one also pack a rudimentary first aid kit?
    Default If i'm driving locally just the usual in the trunk, spare tire, jack ,
    a couple of the cheapo coleman survival kits that go on sale all the time at big five, they have survival blankets waterproof matches lumisticks etc. A first aid kit thats fairly current. jumper cables, some oil, a couple gallons of water and some rudimentary tools, pliers,screwdrivers, wrenches etc in addition to the factory toolkit. If i'm going on a trip i take along more tools, more water and some food. I usually take my 1/2 cordless impact wrench charged up and some sockets for it. and a lightweight aluminum floorjack that i have, provided that there's room for it. I have a nylon tow strap that i also take and an old blanket to lay on if needed, blue shop towels, a rechargeable trouble light... I go a little overkill but since i don't use cellphones or AAA i prefer to be prepared.. Usually i end up using the impact and the floorjack on someone elses car that i run across with a flat somewhere on the road. Haven't had to use it on mine ever. but if i didn't bring it then something is going to happen.
    Austin, TX
    Right now i have this in the e39
    - water pump + t'stat
    - spare coolant hoses
    - spare coolant
    - 3 jugs of distilled water
    - mag-lite + extra batteries
    - all the essential tools
    - one of those battery pack/air compressor things
    - duct tape, zip ties, and hose clamps (these 3 can almost fix anything)
    - 2 blankets and pillows, jacket (in winter)
    - Power inverter
    - the saigon whore that bit my nose off.
    Quote Originally Posted by JAlfredPrufrock
    being caught off gaurd is half of the adventure, you wont have a good story to tell if you are prepared.
    Black/Black '90 535IM..... '65 Cal look vw bug
    i posted a long @$$ list on the previous vbulleting board of my stuff.
    1 gal water in the city. 2 gal if travelling on the highway. if you need to add water in an emergency situation, it doesn't make sense to add coolant (as you might lose it again) so i don't carry it.
    1litre of ATF, my steering runs on it too.
    1l of the unused old brake fluid from my flushes (ie, if i do a brake flush, and i don't use the opened bottle within 3 months, i pour it into this container)
    an m50 ignition coilpack
    jumper cables
    an ICV
    breaker bar pipe
    a 17mm socket on a real wrench in case the car's lugwrench doesn't cut it
    2 kinds of epoxy
    a hose bandage
    1 L of oil
    1 jackstand, in case i have to do things on a slant
    a voltage regulator for my alternator
    tow rope
    headlight bulb
    fuel pressure gauge
    spare radiator cap
    10 or 11 extra hose clamps of various diameter
    volt ohm meter
    electrical tape
    fuse link and some assorted fuses
    1 of each taillight bult
    length of generic american heater hose
    fender cover in case i need to seriously "go to work" on things
    a collection of nuts and bolts from when i repair things on the car and replace them with new bolts
    loctite
    bentley paper manual (i keep the cd in the house somewhere)
    lots of other stuff i can't remember
    box of tools with allens, torxs, wrenches
    this all fits neatly into two toolboxes, with the exception of the jackstand
    Hi Ryan, thats a long list. it seems very long. I've never considered what to take in my car, I only use the stock equipment and that's it. Can you show me some pics of the tools and/or toolboxes with gear in it. How you do secure it down in the boot?
    Default Not much...
    Fire extinguisher
    Rad hose repair kit
    Fuel hose repair kit
    Fuel tank & Radiator repair kit (stick)
    Tools in a small packpack. Toolbox is too bulky.
    cheater bar
    1 outfit to change into
    Jumper cables
    Some adhesives
    Small jack
    Rags
    Coolant mix
    Refreshments
    Some grub
    Tire pressure gauge
    Car wax
    CDs (always)
    and last but not least condoms...
  10. #20
    Dayton, Ohio
    Quote Originally Posted by Qube
    I do I do!
    but only becuase its the BMW one which is under the passanger seat.... the stuff in there is probably so old that the bandaids probably won't stick anymore..
    guess I should update it a bit
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
  1. BMW Emergency Fuel Can
    By LunatiC in forum 5 Series BMW
    Last Post: 04-27-2007, 06:57 PM
  2. Replies: 1
    Last Post: 08-13-2006, 03:24 AM
  3. Emergency: Need your help with screwed up suspension...
    By uflnuceng in forum 5 Series BMW
    Last Post: 07-14-2006, 11:42 AM
  4. Emergency: what happened?
    By mzarifkar in forum 5 Series BMW
    Last Post: 02-18-2006, 01:58 PM
  5. LAD kill in emergency
    Last Post: 10-18-2005, 11:17 PM
