Congrats, should be a nice addition to the stable.Originally Posted by tibbe
Display sounds like a bulb is dead, you can call the manufacturer (Alpine or Pioneer) and get replacements for a couple dollars (or Euro's ) each. Then it is popping the cover off the radio and soldering them into place. It is really quite simple. If some stations aren't there, pull the radio out (two set screws on each side under the flaps) and see if the antenna is loose or not hooked up.Originally Posted by tibbe
Sounds like the LCD may be on its way out. Do the dots ever appear in the "missing" spaces"? Probably the easiest thing to do for replacement would be to replace the cluster with a used one rather than trying to find the indicator.Originally Posted by tibbe
http://www.unofficialbmw.com/e36/ele...ce_lights.htmlOriginally Posted by tibbe
Note: Any way you want to jumper will work (Wire or paper clip).
Can't help you there, never dealt with the rear wiper....Sorry.Originally Posted by tibbe
http://www.bmwe34.net/e34main/mainte...oorRemoval.htmOriginally Posted by tibbe
It can be kind of fun. E34's are great in the snow with a good set of snow shoes. Enjoy!!Originally Posted by tibbe
Best,
Rory
