the very, very short answer to this is....if the back or front of the oil bottle says meets xxx oil standards for (mb/bmw/ford/catepillar) diesel, it is an acceptable diesel oil. diesel oil usually contains more dirt control components since diesels naturally have more particulate as a product of combustion than gas engines do. diesel oils might have a different additive package in certain hemispheres/climates because of differing catalytic converter construction/lack of catalytic converters....these cat. ingredients might be sligtly harder on a gas engine's cat than a gas oil is supposed to. i'd go to the place you normally purchase engine oil from and look in the section that has traditional diesel oils (they are usually seperated somewhat), and work from there. for example, in N America, the two main diesel oils are Chevron delo 15w40 and shell rotella 15w40. the full syn would be below these oil, marked Full synthetic rotella or chevron delvac 1 (full syn). diesel oil or such. that's how i'd determine such. in your f250, IMHO (and its not worth much) i wouldn't put anything other than a branded diesel oil into there, not passenger car stuff. up to you whether or not you want that to be a synthetic. oh, and FYI, most places on earth do not use as heavy an oil as is marketed in Oz and such, 50 weight is considered obsolete here, that's why mobil 1 is sold as 0w40 as the fattest, and 15w50 here. please understand this if you feel that an oil you use on a regular basis isn't getting enough talk time on the board. if you are looking for a dedicated diesel oil, check the back for a glut of diesel certifications and a lack of gas ones, or look below the diesel oils in the store.
