Easy! Microfilter... change it!
Newbie here...first post! I am also not very mechanically inclined when it comes to autos. However, thought I would post my problem and see if there is anything I could check before I incur a costly repair bill. BTW, I do have the Bentley service manual. My problem is that the air flow on the A/C is cold, but very low volume. With the current temps in the Denver area exceeding 100 degrees, driving is unbearable. Any thoughts on what the problem(s) may be? Thanks...![]()
Not very fun to change the microfilter, but well worth it.
Ryan
1994 525iT
I saw that in the Bentley and thought that could be the problem! Thanks guys. Can you run it without a filter until I can get one?Originally Posted by Tiger
Doesn't look like it!! Are they also called ACC Cabin Filters...about $25 online??Originally Posted by rps1072
Would you run your house A/C without one?
Ryan
1994 525iT
Considering that many e34s didn't even come with a microfilter, I don't think it's a terribly bad Idea - unless of course you are sensitive to allergies, etc in the air.Originally Posted by rps1072
You mean I could spend the time tearing out the glove box, trim panels, etc. and find out that I don't even have one?Originally Posted by Hypr5
Yep, i did mine...changed the m/c & recharged the refrigilant.
Now, my a/c is freezing my a$$ !!!
'95 BMW-540i/Auto (ZF-5HP30)...NO reverse
"Original" Nikasil block (+ Fristo Lays Chip)
87+ K Miles
No, you don't have to tearing it apart...just to find that your bimmy doesn't have m/c equipped.
Refer to the service bulletins, only the models after 1991 are equipped w/ m/c.
87+ K Miles
