Results 1 to 3 of 3
Thread: shimmy from rear end.
    Mar 2004
    Default shimmy from rear end.
    I just had my mechanic replace:
    -rear subframe bushings
    -new rear shocks and shock mounts
    -new brake discs and pads
    -all new front end
    There is still a shimmy felt in the car while braking, and it comes from the back, as the shifter moves left to right in tandem with the shimmy.
    He said there are some bushings back there in the subframe which would likely be causing it, which are common to go.
    Is this sounding familiar to anyone? Which bushings?
    Jul 2004
    Montreal, Canada
    dogbones??
    I had a mild rear shake and the dogbones fixed it
    ^°^ ><((({º>°°
    baton rouge, loserana
    during braking? it's a warpped rear rotor
  1. rear brake replacement solved shimmy
    Last Post: 12-23-2006, 10:27 PM
  2. high speed shimmy/vibration?-check rear brakes
    Last Post: 12-19-2006, 08:32 PM
  3. shimmy shimmy shake
    By diamond777 in forum 5 Series BMW
    Last Post: 06-30-2006, 09:32 AM
  4. 50-60 shimmy perhaps???
    By azzurribaggio in forum 5 Series BMW
    Last Post: 12-24-2005, 07:36 PM
  5. rear 'shimmy' of sorts
    By chamilun in forum 5 Series BMW
    Last Post: 11-24-2004, 05:01 PM
