Results 1 to 10 of 16
Thread: Rearview mirrors - which years work for E34?
    Apr 2005
    IL
    Default Rearview mirrors - which years work for E34?
    I want to replace my boring E34 mirror and have found one from an E39 2001 525i. Will this work or are there other years that will work? Is there a list any where?
    Ken
    i am not sure what kind of mount the late e39 has, look at the receiver on the end of the stalk that cams onto the button on the glass, if it looks the same it'll probably work, i am running a late e32 auto dimming mirror in mine, some people have retrofitted red/orange leds in the bottom of the older mirrors to be kinda like the later cars with their soft console lighting
    The later e34 models were equiped with a newly designed rear view mirror that will fit - not to sure about the e39.
    Quote Originally Posted by zuzuk212
    Ken
    Ken
    Yes. The E39 will work! I have fitted an E65 electro-chromatic rear view mirror w/ UGDO (universal garage door opener). Just twist your RV mirror (carefully, to the left or right at the base) it will come right off. Good news is the E39, E65 (E60 too I imagine) uses the same metal base that is adhered to the glass! What is great is I have my alarm wired right into the E65 R/V mirror so the "clown-nose" flashes just like they do on the E39, E65, E60, etc... Running the wire from the backseat was kind of a pain, but it was worth it! I still have to hook the UGDO up (we are supposed to be moving into our new house next week- so I'll FINALLY have a garage AGAIN!) & the Electro-Chromatic as well. Check eBay, there are E39 mirrors on there every once in a while.... I also ordered the black plastic base that snaps over the mirror base off the E65- fits right on the E34!
    Don McAdams
    McAdams AutoSport
    www.McAdamsAutoSport.com
    '95 E34 525iT
    '88 E30 ///M3
    '85 E30 325e
    Vero Beach, FL
    Apr 2005
    IL
    Thanks!! And the photo is awesome!
    Thanks again, hopefully I'll get one to work. I'll post when I do.
    I've done this as well. Picked up a Gentex on eBay for about $10, pulled the old mirror (and the button because the Gentex uses a universal mount). Life will be a lot easier using the OEM button if it'll work Then wired up the autodimmer -- the harness is located behind the left side (driver's) vanity mirror and it works wonderfully
    best, whit
    Apr 2005
    IL
    Default Does the E39 dimming mirror cause locking problems?
    Quote Originally Posted by Don McAdams
    Don or anyone else,
    ... I'm still searching for a mirror since UPS lost the mirror I won from ebay. I found another but the owner says:
    "Please note this mirror is not suitable for earlier model cars without the red dome on the base of the rear view mirror, as otherwise it messes up the central locking system and you can't get back into your car. It is therefore not suitable for E34 E32 E36 models, even though it would 'fit'."
    Is this true or is there a way around it?
    Long Beach, CA
    Something to research further.
    Don or anyone else,
    Need to know what exact year it is out of....?? I just hardwired the LED wiring from my alarm all the way up behind the headliner to the mirror base- The E39, E60, & E65 is a direct fit. Just CAREFULLY twist the mirror base & the mirror will come right off. The same metal mounting base is used-
    Keep us posted
    Don McAdams
    McAdams AutoSport
    '95 E34 525iT
    '88 E30 ///M3
    '85 E30 325e
    Vero Beach, FL
    Apr 2004
    Reston Va
    The e39 Mirrors are not open to being wired through the plug and Stock Harness to work properly. This was my experience as I have the Central Locking System Key reciever in my mirror. I bought the e39 Mirror and tried to wire through the plug the Central Locking system AND the electrochromatic functions. It did not work. I ended up getting a e32 mirror with Electrochromatic and then splicing the reciever board into the harness through the plug. Now all is well and all works as it should. But - save your $$ and go for the 32 Mirror. It works and works well - JT
    Johntee540
    1994 540/6 Black - Tan - 199k
  1. rearview mirror
    By compmore in forum 5 Series BMW
    Last Post: 11-28-2006, 10:31 AM
  2. Auto Dimming Rearview Mirror -- Anyone have one
    Last Post: 03-06-2006, 03:16 PM
  3. Replies: 60
    Last Post: 08-10-2004, 12:37 PM
  4. Where does the internal rearview mirror latch on to?
    Last Post: 06-18-2004, 07:31 AM
  5. Outside Rearview Mirrors
    By Steven G in forum 5 Series BMW
    Last Post: 05-10-2004, 06:21 AM
