Thread: Got this huge oil cooler for free
    PA
    Default Got this huge oil cooler for free
    I work @ Land Rover and whenever a hard oil line leaks on the trucks, they pull the whole oil cooler out and discard it. They do this because they're.... stupid. They don't sell just the lines, so the customer has to buy the whole unit. So now I have a 24" x 2" x 2" oil cooler with end tanks Just need lines. Any one ever install an oil cooler or know the easiest way?
    Sweet catch, man.
    I'm not quite sure where you'd mount it (E30-bottom-of-the-radiator style?), or even how to integrate it with the M50, but seeing as how you're getting ready to drill holes in the oil pan for your blower setup, it can't be that big of a job. Since you'll be doing custom pipework, it might be a good idea to pick up an A/C crimp fitting die ki.
    I just installed a 15 x 11 (? think those dims are right) trans cooler behind the bumper. Just enough room to make it fit on my auto 535; you should have tons of room on the 525iM.
    best, whit
    Long Beach, CA
    Stock for life except for an oil cooler.
    PA
    Quote Originally Posted by uscharalph
    and rims, suspension, custom exhaust, custom interior, supercharger, hids all over the front of the car...
    Bellingham
    ...or cautious. It may be difficult to isolate a leak to the line and rule out the cooler. A leak in an oil line is serious business, because failure of any of these components means bye-bye engine.
    For that reason (and because it's completely unnecessary) I'd not bother with the added risk.
    Bruno used to sell adaptor plates for the oil canister mount which allow you to run lines to a remote filter. If you want to install this; use that adaptor and run a line through the cooler and a remote filter than back to the block.
    PA
    Quote Originally Posted by Mobius
    This specific cooler holds pressure. No leaks.
  1. OT, do other cities have a huge problem with
    Last Post: 01-23-2009, 04:48 PM
  2. Huge Mahalo to Blitzkrieg Bob..I have A/C!
    By HIe34 in forum 5 Series BMW
    Last Post: 05-07-2007, 03:08 PM
  3. Do I Have A Huge Problem?!?!?!
    By BMW4LIFE in forum 5 Series BMW
    Last Post: 11-14-2006, 12:38 AM
  4. Trans Auto Problem, Really Huge
    By dafuzzymuff in forum 5 Series BMW
    Last Post: 07-20-2006, 05:43 AM
