Thread: what wrench to change the coolant sensor?
    Lexington, Kentucky
    Default what wrench to change the coolant sensor?
    I changed my coolant sensor last weekend on my 95 525i M50 engine. Had a bit of difficulty in getting the new one tight. Not much room under there. Think it leaks a little.
    What type of wrench should I use?
    BTW, I still get the coolant level light-but not all the time. I think it s electrical. Now going to check the wiring.
    Thanks in advance
    Lexington, Kentucky
    Default Help-it still leaks -Cain't get it tighter
    BTW, I still get the coolant level light-but not all the time. I think it's electrical. Now going to check the wiring.
    Thanks in advance
    needs to be tighter!
    get on in there and tighten the bugger up!
    wooo wooooooooooo
    Lexington, Kentucky
    Default Ok what wrench?
    The wrench is the problem as I stated in my first post on this issue. I cannot find any small open end wrench or plyers to fit so I can tighten the plastic nut. The area is very constricted. Am I missing something here?
    wooo wooooooooooo
    Fogtown
    I broke my coolant sensor by over-tighting it. I changed mine by removing the radiator. I really don't think that you have tighten it that hard to stop any leaks (its plastic).
    Use a pipe thread sealant or teflon tape.
    Bellevue WA
    86 Porsche 951 - Track Toy
  1. 02 Sensor Wrench
    By philbyil in forum 5 Series BMW
    Last Post: 06-30-2009, 10:30 AM
  2. Coolant Change
    By Golgade in forum 5 Series BMW
    Last Post: 10-25-2008, 11:55 PM
  3. Update on o2-sensor Change
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 01-31-2007, 06:47 PM
  4. Coolant change help needed
    By sharkhog in forum 5 Series BMW
    Last Post: 01-21-2007, 05:35 PM
  5. M60 Coolant Change -
    By zman-95-540i in forum 5 Series BMW
    Last Post: 10-07-2006, 09:31 AM
