Hello! I have a problem with my ABS System and nobody knows how to fix it. If anyone has a electric scheme of ABS or other instructions please help me! Thanks! I have a 520i, 1990, a clasic one, not vanos!
which problem do you have?
ABS wiring diagrams:
http://www.e34.de/tips_tricks/schalt...50_0/index.htm
I've already checked out that link and iI found diagrams for models made in 1994! Are those diagrams good for me? My bmw is from 1990!Originally Posted by Kai@e34.de
I think that my problem is with Abs's wiring! It is strange because my ABS's led in the dashboard does not light when i put the ignition on, but when i stop the engine!
I've checked the ABS control unit, the fuses, relays and the ABS pump and are all good! That makes me think that my problem is with the wiring!
Thanks for trying to help me!!!!
Regards from Romania,
Florin Temciuc
What about the dash module itself? If it's the euro kind with the clock ODO, versus digital, I don't have a clue. But, I'd be assuring that the dash module itself is working prior to messing with the ABS.
Case in point: when I bought my car, the EML light on the dash stayed on, key or no key in the ignition. Only problem is, my car doesn't have EML -- the light was just grounding out, thereby staying on all the time. After ~ 15 years, the electrics start to act up sometimes... I ended up pulling the light....no more problems.
best, whit
