I attempted to drill out and extract a broken exhaust stud from my M30 head, but apparently i must be slightly off center since it will not turn out (The extractor must be catching on the heads threads.) I successfully removed the other broken stud with a penetrating oil, a torch and vise grips, since it was protruding enough to get a grip on it.
The stud is 8mm OD and I have a 6mm+/- hole drilled through it, the stud was snapped off about 1mm below the gasket surface. So, now it is nothing more than a thin hollow cylinder stuck in the hole. How can i get this out? Right now I'm thinking its about time for a machine shop to just drill out the remainder and put in a heli-coil, but I'd like to try any other DIY methods first...
