Results 1 to 3 of 3
Thread: Condensation in a fog lamp...
    Apr 2005
    The Bronx, NY
    Default Condensation in a fog lamp...
    Recently--about 2 wks ago, I noticed that one of my fog lamps (just the driver side) has some condensation inside.
    Anyway, I took both of them out & clean up the lenses & housing good. (You wouldn't believe there was a film of dust lining inside the lense.) While I took the lamp apart, I also checked for a sign of any crack...nothing, nada...the housing & lense looked OK. No sign of any crack was found. (Except, there are 2 small openings for heat-ventilation; one on each side.)
    Put both lamps back...(it's light much brighter) & drove in the rain last wk. Well, yesterday, I found the darn fog lamp (the same one on the driver side) just has a condensation inside the lense again.
    I'm thinking about re-seal the seam (where glass lense & plastic housing contact). Just wonder if anyone has BTDT...Any suggestion on the material should I use & where should I seal it?
    Many thanks,
    CC1
    '95 BMW-540i/Auto (ZF-5HP30)...NO reverse
    "Original" Nikasil block (+ Fristo Lays Chip)
    87+ K Miles
    you most likly have a leak where the front glass and the housing come together, I inspected mine and used some cool red silicone...mistake. Use black all around the seal after you clean it up and that should take care of it.
    Apr 2005
    The Bronx, NY
    Many thanks for your advice, Jeff.
    It'll be keeping me busy (& a bit messy) this wk-end.
    87+ K Miles
  1. Replies: 5
    Last Post: 06-16-2008, 10:28 AM
  2. indicator lamp
    By julian1966 in forum 5 Series BMW
    Last Post: 02-23-2008, 06:07 PM
  3. 525iT FREEZES...condensation in the tank? HELP!
    By aviatorb747 in forum 5 Series BMW
    Last Post: 03-18-2007, 06:21 PM
  4. Condensation in both LH headlights
    By bagpuss in forum 5 Series BMW
    Last Post: 09-24-2006, 06:53 PM
  5. ::.. LF: Fog Lamp Connector
    By Qube in forum 5 Series BMW
    Last Post: 02-09-2006, 12:37 PM
