Just did mine too. Coolant level sensor. Aux fan switch (probably can reuse yours). Bleed screw. Did you say upper brackets? Maybe a couple of new expanding rivets for the fan shroud.
Have fun.
I was just placing an order with BMA to complete my cooling sytem update. I ordered a Nissens radiator last week. I ordered a Vernet 80 degree thermostat, a Hepu water pump, various hoses, transmission fluid connection o-rings, radiator mounts and a 2.0 bar radiator cap. Anyone have any comments / suggestions before a push the button?
Have fun.
Ryan
1994 525iT
various hoses...are you going to replace all the hoses?
Radiator mounts, u mean those clips at the top? They break easily and should have some of those on hand.
Current
2008 M5 6 Spd
2000 Z3 2.8 5 Spd MSport
2012 X5 35d Sport
1995 540i 6 Spd
1992 535i 5 Spd
Former
1995 530iA
1986 635CSI 5 Spd
2011 X3 2.8 MSport
Not if one knows how to undo them correctlyOriginally Posted by DaCan23
The trick is to use a thin, flat blade screwdriver about 10" long. What most people don't realize is that there's a part that grabs the lower edge of the rail. So, press DOWN and push towards the hood and you probably won't shatter a clip.
Ralph....replace all hoses while you're at it. Don't let them sell you OCAP, specify CRP (ok) or BMW OEM (best). And make sure you have some good hose clamps around if the old ones are shoddy.
best, whit
Don't matter if they are 10 years old and baked. Brittle and they snap. Get some new ones...Originally Posted by lowell
Bellevue WA
86 Porsche 951 - Track Toy
The PO replaced all but 4 of the cooling hoses, so I'm replacing those 4 plus the upper and lower again (I figure those would be good emergency hoses to carry). The radiator mounts I was referring to are the plastic clips on top. 5 out of the 6 hoses are CRP, the other is Conti.
By the way, when we did the cooling system overhaul, we didn't break these clips. I still installed the new ones, but I have spares now.
