Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Need oil change recommendations
    Aug 2004
    Southern California
    Quote Originally Posted by hubster999
    Hi guys, I'm about to tackle an oil change on my wife's 1994 525iT, and since it didn't come w/ an owner's manual, I'm looking to see what you guys would suggest to use, what brands and etc. And how many qts. does it take? And any little nuggets of info would be appreciated also-Thanks in advance!
    And I live in Ohio also..............
    hubster
    try Voll-Synthese 5w40, I had been using them for a long time, and no leaks,LEAKS depends on your engine itself if been neglected before. While you're at it, try JECTRON fuel injection cleaner with our oil change, I did feel the difference IMHO.
    Nov 2004
    Winston-Salem, NC
    Default Hey Man
    hubster
    My M50 (you have a M50TU) uses 6.1 quarts of oil. I use Valvoline Max Life 15w50 (dino). I looked hard at a lot of oils and spent time reading the BTOG forums.
    I decided to use dino oil for three reasons
    1) I didn't want to take a chance that my small oil leak would turn into a big oil leak with syn oil.
    2) $2 a quart vs. $5+ a quart. For $12 (plus filter) I can afford to change my oil more frequently.
    3) The Valvoline oils have a really good detergency action and my engine needs a cleaning.
    As to the filter you can order them through BMA (bmaautoparts.com) or if you're a BMWCCA member you get a discount at the parts counter of your local stealer. I pay $10.59 for the filter kit (includes crush washers and o-rings) and that's just a few cents more than what it would cost to get through an online parts supplier once you factor in taxes, S/H, and all that.
    BTW you'll need a 17mm rachet for the drain plug on the oil pan.
    -ashley
    Paper Gaskets Suck!
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by Jean@MtMiguel
    I've been wondering if that stuff works. So, you did notice a difference then? How do you use it (add it to the gas, oil, etc...)?
    -ashley
    Paper Gaskets Suck!
    Philippines
    Castrol Formula RS 10w50
    synthetic definetly
    Aug 2004
    Southern California
    Quote Originally Posted by acyre
    -ashley
    Add Jectron to fuel tank, my experience I add Jectron with about less than half tank full and refuel at about less than quarter to maximize the strength. My local part outlet said that most of the indy repair places uses Voll synthese with their oil changes now due to customer request.
  1. Any Recommendations?
    Last Post: 09-28-2007, 09:55 AM
  2. Oil Change Recommendations for Calgary
    By AllGo'n'Show in forum 7 Series BMW
    Last Post: 12-27-2005, 02:30 AM
  3. Replies: 5
    Last Post: 11-19-2004, 08:16 PM
  4. How hard to change timing change tensioner in M50?
    By sc156k in forum 5 Series BMW
    Last Post: 06-06-2004, 11:35 AM
  5. Recommendations re. 7's
    By Mitch90535im in forum 5 Series BMW
    Last Post: 05-01-2004, 05:41 PM
