the later e34 has a 3 channel abs pump, rf lr and rear, all have two lines from the master to the abs pump. the early cars 91 and older have a 4 channel pump. when i built my e34 i had to convert the braking system to the later abs system because i used a 92 body wiring harness and it wouldn't work the early pump, and because my luck sucks the 1st pump was bad, the left front wheel would lock up and stay locked till the pressure was releaved. i wound up using a e30 pump with the electronic controls soldered onto the solonoids, because i couldn't find the right unit, here we are 2 years and 27k miles later still absing away. it's possible that you are having a problem like that
