Results 1 to 10 of 20
Thread: '94-'95 mirror covers?
    Feb 2005
    Richmond, TX
    Default '93-'95 mirror covers?
    I just got a set of '95 mirrors for my car and want to get the covers painted. Do they just pop off with a little prying or is there a fastener hidden in there somewhere?
    I don't want to pull on them if I'm not supposed to.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2000 323iT - UUC BBK, PSS9 Coilovers
    2005 GMC HD Crew
    I have tried to pop those off but failed. End up just mask off all the black parts.
    Toronto
    Default In order to disassmble the mirrors
    you have to remove the speakers (tweeter) on the door at the front. Once you remove it you can get access to the bolt that holds the mirror in place. Once you remove that, you should be able to remove the cover. I have never done this myself, but this is what I have been told.
    Feb 2005
    Richmond, TX
    Quote Originally Posted by western99
    No, the mirrors are already off the car. I'm talking about the part of the mirror that is painted body color.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2005 GMC HD Crew
    Toronto
    Default Brodee, send Bruno a PM, he definitely will be able
    to tell you all the details. You should be able to remove it since I got my driver's side mirror repaired (crack fixed and painted). Sorry that I could not be of more help.
    May 2005
    SUFFOLK,ENGLAND,GREAT BRITAIN
    Tried and gave up. I only wanted to do it so I could service the motors whilst the mirrors were off. But decided I was more likely to break something and regret it.
    One them jobs!
    Ian
    Default Yes you can remove the painted part...
    Quote Originally Posted by brodee
    Do they just pop off with a little prying or is there a fastener hidden in there somewhere? I don't want to pull on them if I'm not supposed to.
    ...but you have to do it from inside behind the mirror glass. Prying it from the outside casing will break it. For painting it's easy to mask up the black plastic - this is how mine were done.
    Feb 2005
    Richmond, TX
    Quote Originally Posted by Phil Sanderson
    I just wanted to pop them off because I want to repaint the black with some SEM trim paint and then do the caps to match the car.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2005 GMC HD Crew
    Long Beach, CA
    I think he's trying to paint the outer black.
    Feb 2005
    Richmond, TX
    Quote Originally Posted by uscharalph
    Trying to do both while they are off the car. I can spray all the black and then sand and prep the caps. tape them off and paint them last.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2005 GMC HD Crew
  1. Replies: 2
    Last Post: 06-10-2007, 01:26 PM
  2. ... Now that I have my Cam Covers Off (M60)
    By Evan in forum 5 Series BMW
    Last Post: 09-10-2006, 12:08 AM
  3. Bmw E34 92-95 Mirror Cover Covers With Turn Signal
    By ktteoh in forum 5 Series BMW
    Last Post: 05-08-2006, 06:35 AM
  4. Replies: 5
    Last Post: 10-15-2005, 11:16 PM
  5. Mirror Controller/Mirror Adjustor
    By salloom in forum 5 Series BMW
    Last Post: 10-25-2004, 11:55 AM
