The photos from Ed were a big help, but here are a few more. I didn't take all I needed since I'm not done with my install, but the grill comes off with the removal of the one screw or wedge on top, then with the hood open, the two center, upper clips by pushing them forward from the engine compartment.
Then the two center, lower clips need to be pushed from inside the lower grill area towards the engine compartment.
Now you will need that 10" screw driver, or I used a long metal rod, to run down this hole to push down the clip at the bottom. These are at the sides of the hood by the open supports, by the directional lights.
Now you should be able to wiggle the grill off. Put a large flat head driver between the seam here, by where this screw comes off, to work it forward. Remove this screw to remove the side lamp grills.
Once you know where to pry, it isn't as hard as it sounds. Hey! I did it!!
Good luck........
Brian C.
