Results 1 to 9 of 9
Thread: Electric Window Stop
    Seattle
    Default Electric Window Stop
    95 525i
    Is there an electric switch that stops the window motor at the top of it's travel? My window goes up and the motor groans to a stop, while trying to split the door. This sometimes leads to the window not wanting to roll back down.
    Seattle
    Still looking for some help here!
    Default My memory is not that good but I believe that the microswitch thats in
    the window is only the limit the downward travel not the upward.. I also think that the amp draw through the general module is what cuts it off on the upward travel
    Quote Originally Posted by joandjo
    Default Limit switch identification.
    Limit switches are:
    RR window S46 Connector X721
    LR window S45 Connector X715
    RF window S44 Connector X743
    LF window S43 Connector X750
    I’ve included some location view for the drivers door so you can reference for any other door.
    Switch is open when window closes.
    If you need help for disassembling the door trimming, just let me know, I can e-mail you some instructions.
    Javier
    explain why my passenger window (only) goes up in 3 incriments, kinds like a pre set distance at a time. have to hit the button 3 times for it to go up all the way.
    Default Electric Power protection relay.
    I think Bill is right. I'm not sure if power protection works when going up or going down, but I think relay K15 is the one responsible for cutting off power when over current to window circuits is sensed in the General Module resistor between terminals 4 and 5. Relay K15 is under the rear seat (See pictures).
    Javier
    Default Over current in the window motor?
    Jeff,
    You may be having an over current condition in the motor for that window, may be the mechanism is sticky and draws too much power, or the motor is in bad shape!! Then the Electric Power protection shut off the power when you operate that window. Try to operate some other window without releasing the switch to the problematic window, If none other works until you release the switches, it probably means the K15 is shooting of the power to the whole system. This is my best guess.
    Javier
    Default hmm if i follow that ill try tomorrow, thanks
    Quote Originally Posted by Javier
    Jeff,
    Javier
    Seattle
    Thanks for the help everyone! I'll try it this weekend.
    Javier
  1. Reversed electric window.
    By ss2115 in forum 5 Series BMW
    Last Post: 07-30-2009, 01:44 AM
  2. Electric Window Problem??
    By brianwolf3 in forum 3 Series BMW
    Last Post: 01-22-2008, 01:01 PM
  3. How do you stop window squeeks
    Last Post: 06-15-2007, 06:17 AM
  4. Rear Electric Window
    By bagpuss in forum 5 Series BMW
    Last Post: 08-17-2006, 09:04 PM
  5. e34 rear electric window
    By dangerous100 in forum 5 Series BMW
    Last Post: 07-02-2004, 03:00 PM
