Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: M30 Engine pull question
    Default Eeeek!
    Quote Originally Posted by Gene in NC
    why can't you drop engine and trans out the bottom like the factory installs it? Works for 2002s.
    I wont touch that one.
    When I used to yank and replace it is definetly easier, and less time consuming to pull the engine trans in a combo...BUT, if you want to just yank the engine without removing the trans thats do-able. Its the reinstall that is going to give you a host of other problems. I never did a bimmer combo but its the same setup as others, I guess to try and see is the only way to make sure. You can always yank the engine back out if you cant couple it to the trans on the install.
    Boston, Ma
    I pulled an M50 out a couple of months ago, and it was a close fit to get it out with the tranny attached. Since the body was trashed, the radiator and condensor were out of the way, and I just the radiator support to make it extra easy. I say I would drop the tranny before pulling the engine.
    Default Think you can - no big lift we can use.
    Bellevue WA
    86 Porsche 951 - Track Toy
    You sure Martin doesn't have one in his garage, next to those fine persian rugs he uses to work upon?
    Robin
    72 Chevy K10
    01 E39 M5
    Honolulu
    Default A hoist with a tilt bar
    Will do it perfectly, without even scratch the trans tunnel.
    If you plan on putting the car back together...don't drop it from below with the cross member. it's easy for a quick stripping job. But it will be a major pain to try to line everything back up while floating the chassis.
  1. Pull engine from above or drop it from below?
    Last Post: 01-01-2008, 11:58 PM
  2. M20 Engine Question
    By begeta50 in forum 5 Series BMW
    Last Post: 03-07-2007, 05:19 PM
  3. OT For the pros engine question
    By Ross in forum 5 Series BMW
    Last Post: 08-09-2006, 10:08 AM
  4. Engine Cover Question...
    By E34 530 in forum 5 Series BMW
    Last Post: 02-26-2006, 12:49 AM
  5. e34 engine question
    By mob1 in forum 5 Series BMW
    Last Post: 10-26-2004, 07:56 PM
