Results 1 to 10 of 16
Thread: Replaced motor mounts-two issues
    i just did a 95 530s motor mounts today it's a fun job, in usa cars i noticed that unbolting the abs pump and lifting it a few inches helped with hitting the left 17mm nut with the 3' of extension and swivel socket, that was a sadistic bastard that designed that position
    Quote Originally Posted by mattyb
    hey russell, thanx for the info. i did it on the weekend. what a bitch of a job, but im sure itll only take half an hour next time. i had only 2 mounts.as for the 5401 the site u sent me to said that the ezhaust needed dropping. not so. otherwise it was great. 10 mm spanner gets under the back nuts easy enough with only a bit of cursing. mounts were about $30 au ea.
    SCHUYLKILL COUNTY, PA.
    Default i changed them in my 540i last year..........
    it was easy & straight forward. i had a garage with tools and a lift to do it in, but i do not remember having to move the abs pump to undo the driver side.
    i did use a 3' extension & a socket with integrated swivel.
    my mounts were torn & the fan was hitting the shroud under load.
    tim s.
    May 2005
    central coast nsw au
    did they appear ok when doing an inspection. mine feel ok, look ok but i wonder?
    Houston TX
    I just did my 530 as well......on drivers side was able to move Brake Fluid Resevoir out of the way....used shallow 6 pt swivel then lots of extensions, could just get to top nut...became religious and it broke free....no problems getting motor mounts out after lifting engine enough..was tight though...
    Long Beach, CA
    I like that: "became religious and it broke free."
  1. Two Motor Mounts and Tranny Mounts please..
    By Jehu in forum 5 Series BMW
    Last Post: 03-19-2008, 12:32 PM
  2. Just replaced rear strut mounts
    By zmuff in forum 5 Series BMW
    Last Post: 03-14-2008, 12:13 PM
  3. V8 Motor Mounts - Interchangeable?
    By Panzer Captain in forum 5 Series BMW
    Last Post: 10-16-2007, 09:35 PM
  4. E36 Motor Mounts
    By Mike H in forum 3 Series BMW
    Last Post: 11-20-2004, 06:42 AM
  5. Motor Replaced @ 60k
    By hinchcliffe in forum 5 Series BMW
    Last Post: 04-22-2004, 12:39 PM
