Replaced motor mounts-two issues
Last weekend I replaced my rubber motor mounts as I assumed they were old enough to cause some vibration. The process went as everyone said except for two minor problems. When I used a floor Jack/block of wood under the oil pan to lift the engine I had the first problem.
Driver’s side replacement seemed to have gone without incident. However, the passenger side of the engine would not lift enough for the rubber mount to separate from the metal engine bracket. My solution was to place a jack stand under the passenger side engine mount bracket and lower the car just enough to separate the bracket and mount. It seemed to work fine.
Second issue was my fault. I forgot to take the bolts out of the radiator shroud. The fan moved up just enough to crack the plastic on the top bolt hole on the driver’s side. Fixed with washer and nut. Just be aware of the issue.
End result-the car seems a bit smoother and actually seems to sound a bit different. Now to replace the four trany mounts.
