Results 1 to 10 of 13
Thread: Damn Rain
    Gainesville, FL
    Default Damn Rain
    I took the grill off. Headlight surrounds off. Bumper off. And suddenly it pours!
    Tomorrow i guess i'll remove the Drivers headlight and see if replacing these power steering hoses is going to be really impossible, or just sort of impossible. I think i'll remove the charcol canister too, that'd give me pretty good access.
    But blast that brake booster! its in the worst spot possible. can i convert my car over to some system that doesn't require one?!
    Gainesville, FL
    did i mention how unimaginably easy it was to get the bumper off? everyone should do it once, if they haven't already, only for the experience.
    LMAO... do you have the write up on adjusting the steering box? That might give you some insight as to the hoses your doing.
    Gainesville, FL
    I've read it sometime.. somewhere. its someplace. =) right now i'm only tackling the low pressure side, so it won't be too bad.
    I might just start another post about this, but will using ATF instead of chf11s actually damage the system? I don't have LAD or servotronic, and i live in a very pleasent climate, so i'd really rather just toss ATF in if i can. i serioussssly doubt the hoses and seals will care at all which fluid i use in the system.
    baton rouge, loserana
    atf should be fine, the problem comes from people using power steering fluid, sort of like people using dot 3 brake fluid and wondering why the master cylinder grommits disolved
    Bay Area, CA
    what kind of atf fluid? any kind, synthetic, dex 3? ????
    www.KaRealtySF.com
    Honolulu
    Default I use Dextron III
    The same stuff that the trans drinks
    Bay Area, CA
    would brand matter? lol
    www.KaRealtySF.com
    Honolulu
    Default I only use the finest Chateau Du Valvoline 1968
    Decant and serve at room temperature
    not really but put something expensive in there if it makes you feel better
    Quote Originally Posted by liquidtiger720
  1. E36 320 after the rain
    By grave77 in forum 3 Series BMW
    Last Post: 06-15-2008, 05:14 AM
  2. just a few drops of rain is enough to get me out
    By filip00 in forum 5 Series BMW
    Last Post: 03-06-2008, 09:59 PM
  3. Why so smooth in the rain ?
    By Claude in forum 5 Series BMW
    Last Post: 07-19-2006, 03:56 PM
  4. My e34 rocks in the rain
    By Gayle in forum 5 Series BMW
    Last Post: 02-28-2006, 05:27 PM
  5. Stalling in the rain
    By White535Mtl in forum 5 Series BMW
    Last Post: 09-20-2005, 06:22 PM
