It is a kickdown button.
Press it with the pedal and it selects the best lower gear for optimum passing power. If your in 4th, but should be in 2nd to pass, it will put you in 2nd.
just curious...
what is the thing under the accelerator pedal for? is it simply to reduce the maximum distance that the pedal can travel or does it do something else?
thanks!
yep, kickdown button
Cool Feature!
kicka$$ button !!!
(He used it on his 540iA--fully Mod, to kick some a$$ on the highway.)
'95 BMW-540i/Auto (ZF-5HP30)...NO reverse
"Original" Nikasil block (+ Fristo Lays Chip)
87+ K Miles
are you driving a stick or an auto?
right?
I've got a 540i 6-Speed, and you can screw it in our out. It kinda seems like a primitive throttle limiter... But I don't know.
Thats done with the TPS isnt is?Originally Posted by JD525IA
welcome to the site, mveale! Same on my 6-sp...although it doesn't really seem to limit the horsies under the hood!Originally Posted by mveale05
p.s. Nice looking car, more piccies would be good!
Cheers,
Duey
