Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Help removing nuts at exhaust header
    Eastern Pennsylvania
    Default Was wundering about a nut splitter
    Several posts have warned about breaking off the studs, and yes I'm removing the exhaust after the header (or manifold) because the bolts at the head looked even harder to remove.
    Have others tried to use a tool to split the nuts on a 6 cylinder exhaust (M50)? It may turn out that after letting the solvent work on the nuts, they'll come off this weekend. It may be a tight fit but I'll purchase a nut splitter if it prevents breaking the studs and having to remove even more of the engine to have the broken studs drilled out.
    Thanks for all of the suggestions.
    Michael Feeney
    91 and 95 525i
    Michael -- let me reiterate that the metal used in the OE fastener hardware is quite soft, and I've messed up threads (beyond using a die to fix them) and cracked flanges due to using some of these more "forceful" approaches. If it doesn't come off after a good PB soaking and a light wrench/socket, I'd get heat on it and it'll be off in a second.
    best, whit
    Default heat it is
    Lowell; Will go with your suggestion. Have sprayed with WD40 for a few days and will use heat before trying to remove them.
    Michael Feeney
    91 and 95 525i
    Jun 2005
    Los Angeles
    Just be careful to make sure that you don't shoot a bunch of wd-40 on right before you put the torch on it. wd-40 is super flammable.
    best of luck!
    Quote Originally Posted by mjfeeney4
    Default really good trick...
    Is to *tighten* them a 1/8 turn before trying to loosen them. I learned this trick from Winfred and it really does work. There's much less chance of breaking anything, and all you really need to do is break the bond and it will back out really easy after that. I use this trick all the time now whenever I have a skinny little rusted nut or bolt. Just turn it in until it pops and breaks the bond and you're all set.
    And please do try the PB blaster. It works. I've used WD-40 and Liquid Wrench for years and never thought they really did much, but PB blaster kicks butt! I used it on a rusty old O2 sensor after all else failed. Just let it sit a while, re-spraying and whacking the bolt with a wrench every now and then to let it settle in.
    HTH
    - Robin
    Robin
    72 Chevy K10
    01 E39 M5
    Default PB Blaster works - another question
    After using PB blaster and letting it soak for a day the bolts came off easily. One problem though is that one of the studs came off with the nut. Was planning on just treading back into the manifold when replacing the exhaust.
    Any suggestions on reinstalling the stud. Should I purchase a new one?
    Michael Feeney
    91 and 95 525i
    Hmmm...depends on how much trouble you want or need to go through with it. I'm assuming it's the 3 bolts per flange setup. You can probably get away with using two studs. If the threading's still good, it might be just as easy to replace the stud (I haven't done it -- I would probably try to find a good substitute).
    best, whit
    Lincoln, NE
    All of the hardware, nuts and studs, was under $20 from the dealer, IIRC. It's a no-brainer in my opinion. Make sure to use anti-seize when you install the new hardware and you're good to go for the rest of the car's life.
  1. removing the exhaust manifold
    Last Post: 03-24-2007, 11:37 AM
  2. header back exhaust
    By alexander525 in forum 5 Series BMW
    Last Post: 02-19-2007, 08:34 PM
  3. On Ebay: complete Hartge header/exhaust system
    By gale in forum 5 Series BMW
    Last Post: 11-04-2006, 01:25 AM
  4. P/N needed: Exhaust heat shield nuts
    By onewhippedpuppy in forum 5 Series BMW
    Last Post: 04-11-2006, 04:28 AM
  5. Exhaust header to front pipe nuts $22.91 US?
    Last Post: 02-26-2006, 03:56 PM
