Results 1 to 10 of 12
Thread: overheating...almost
    Wisconsin
    Default overheating...almost
    Have any of you ever had something like this happen?
    My 1995 525i gets hotter than the 1/2 way point when I am stuck in traffic with the A/C on. When I turn the A/C off, the needle falls slow. I believe the aux fan is working properly because I have checked it when the car is warm and it is running. The clutch fan is new (first attempt at fixing it). The water pump bearings seem to be fine, no slop in the fan at all. The serpentine belt is tight and all of the tensioners/ idlers are functioning properly.
    I have not been able to check the functions of the 'T' stat.
    Figured that I should ask the experts before I make another stab in the dark at it.
    Joe
    Long Beach, CA
    The aux fan should turn on whenever you turn on the a/c. So when the car is cool, turn the a/c on and check to seem if it's on.
    Aug 2004
    Milwaukee, WI; Chicago, IL
    Never hurts to do a coolant bleed.
    1990 BMW 535i 5 speed - Black on Grey, LSD
    Apr 2005
    The Bronx, NY
    Default 1st, pls...
    check if the aux fan is working or not?
    (May be the resistor pack was already burnt out... and, this could possible shut off the aux fan too.)
    Good luck...
    '95 BMW-540i/Auto (ZF-5HP30)...NO reverse
    "Original" Nikasil block (+ Fristo Lays Chip)
    87+ K Miles
    Next step could be getting the radiator flow tested. I went through the same thing a while back, and found out the radiator was 75% blocked.
    Wisconsin
    Aux fan is working. I do need to confirm a second speed (?). How can I check the flow of the radiator?
    cant really check the radiator for flow, have to take it in. Check it out closely around the hose inlets, they tend to blow suddenly.
    Does your car sound like a schoolbus with the air on and hot in traffic? I read that you put a new clutch for the fan, maybe it isnt working properly.
    Mar 2004
    MASS
    Default If you can get your fan off then...
    take the radiator right out. I took mine out last weekend. Its real easy after draining.
    I flushed it with a hose and some crap came out. Seems to run a tad cooler. Clean between the fins too.
    Wisconsin
    Quote Originally Posted by Gooch
    I will try this, hopefully this weekend. Thank you
    Wisconsin
    It sounds like a bus...this is good right?
  1. Overheating?! Not Again!!!
    Last Post: 07-23-2007, 10:53 AM
  2. Is your M50 overheating ?
    Last Post: 06-13-2007, 01:13 AM
  3. Overheating
    By uginer in forum 5 Series BMW
    Last Post: 12-25-2006, 12:39 AM
  4. car overheating, need help
    By misfortune in forum 5 Series BMW
    Last Post: 11-26-2006, 12:34 AM
  5. overheating
    By blaze12 in forum 5 Series BMW
    Last Post: 07-09-2004, 09:59 AM
