Results 1 to 3 of 3
Thread: Antifreeze leaking
    Default Antifreeze leaking
    Hi,
    I have an E38 and there is antifreeze leaking from the car. The other day I checked the fluids and noticed that the antifreeze looked low. So, I filled it to the top the way I would on any other car. The car is not overheating and I am not sure why this is happening.
    Was I not supposed to fill it to the top????
    Any Help would be appreciated??
    Default not to fill to the top
    Have a look at the expansion tank. There are 2 marks for low and high. The liquid should be within these 2 marks, close to high level.
    Also remember when the coolant gets hot, it will expand. If you fill up to much, it will disappear thru the overflow. Also see owners manual.
    Check the whole engine room for marks of coolant, usually the colour (if you use the original coolant) is green. These spots are easy to see. Also remove the black cover from the heater valves and the aux water pump and check the connections. Use a small mirror and look at the bottom of these connections, also under the water pump.
    Thanks Shogun,
    Took a look and leaking seemed to stop. I think I just filled to much.
  1. don't fill her up with antifreeze
    Last Post: 10-09-2009, 07:20 AM
  2. Antifreeze in oil-- 91 525i with 242,600 miles
    By semiretired in forum 5 Series BMW
    Last Post: 01-15-2007, 06:19 PM
  3. Antifreeze Leak
    By Luftpost in forum 5 Series BMW
    Last Post: 05-26-2006, 04:43 AM
  4. Why 100% Antifreeze is not good
    Last Post: 12-27-2005, 04:29 PM
  5. antifreeze question
    By chamilun in forum 5 Series BMW
    Last Post: 09-01-2004, 03:09 PM
